I have a 1HP Grundfos 3 wire pump with a Franklin Control box I use this for irrigation when I turn it on usually you hear the relay kick in but you hear nothing and then after a few seconds the reset trips. Everything seem to check out good in control box start cap was a little leaky replaced it and no help, ohmed ot pump seems to be within specs. Don't know what to check next any ideas would be appreciated, is there a way to check pump without having control box in the loop. Any test i should do to pinpoint problem.
