Well, I liked this one too. It's rated 154' total head pressure. The pside-kick will be right by the tank...so no real head pressure caused by depth. So wouldn't 60 psi x 2.31 = 138 head, so this pump would fill the pressure tank when flow is 0. But then when I'm running water - at 50 psi running through the pipes, and let's say a 20' total height from the tank in the basement to the highest fixture in the house, that's (50 x 2.31) + 20 = 135' head. That pump will push 5gpm at that head. Thoughts on if that all makes sense?
https://www.amazon.com/Hallmark-Ind...3PR82TAD4X3&psc=1&refRID=THECYQXRN3PR82TAD4X3
No, not enough head. 150' = 64 PSI. You don't want to run a pump that close to it max pressure using a 40/60 switch. Use the 1HP and let the CSV make it pump a 1/2HP worth of water when needed.
