Pros: how do you work with huge (12”+) PVC?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pat G., Jan 14, 2018.
  1. Pat G.
    Pat G. New Member
    Nov 6, 2015
    Fort Mill, South Carolina
    I was at Great Wolf Lodge this weekend with my kids (chain of indoor water parks for the unfamiliar) and was marveling at the water supply plumbing for the water slides. It looked like plain old PVC with the various elbows and markings, etc, just on a massive scale, looking like 12-18” OD to my eyes.
    I have no intention of ever working on this stuff, but was curious as to how the pros handle stuff this massive and presumably heavy. Do you use us standard primer and cement? How do you cut it? Etc?
    It looked like some crazy stuff to plan and install, especially as some of the runs were 3-5 stories tall and putting massive volumes of water into the slides.
  2. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    Pipes 6" to 12" are joined slightly differently than small pipes. Same solvents are used and in addition, there is a coupling and an O ring built in the receptor pipe.
    So how do you push them together?
    For 6" pipes you attach rings with nuts and bolts. You tighten the bolts and the two pipes join together. For 12" pipes you use a heavy machine like a backhoe to do the pushing, lifting and moving the pipe sections. On a PVC pipe line construction, 3 guys spend about 3 minutes to connect a joint (trench digging not included). For less than full pieces, you use sledge hammer and plywood or 2x4 to join them.
    Cutting large pipe is fun. You can use a hand ring cutter, or you can use a Makita 6101 gas-powered 14" blade cutter. It works almost like a chainsaw, but you have to be experienced to get straight cuts.
  4. Pat G.
    Pat G. New Member
    Nov 6, 2015
    That sounds amazing, thanks! It was cool to see this stuff out in the open since I would imagine most of the big PVC is buried.
Similar Threads: Pros huge
Plumbing Forum, Professional & DIY Advice Hot water heating zones, pros and cons Jun 22, 2014
Plumbing Forum, Professional & DIY Advice Venting Questions for the Pros Apr 30, 2014
Plumbing Forum, Professional & DIY Advice Does my pipe have leprosy? Jun 12, 2010
Plumbing Forum, Professional & DIY Advice How the pros do it? Nov 20, 2008
Plumbing Forum, Professional & DIY Advice PEX Pros and Cons Nov 13, 2007
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
