DStyduhar
Hi all,
Installed a new sub pump, hose, wires and CSV last weekend but struggling with adjusting pressure on CSV. The CSV is at the well head and the pressure tank/switch/gauge is in the house. Everything below is with our one shower running
1. When I am adjusting the CSV, it takes minutes before the change becomes apparent on the gauge in the house. I mean, I can take the bolt completely out and it seriously takes like 20 minutes for the gauge pressure to show change of 10 psi. This doesn't seem normal. There IS another check valve in the house between the CSV and pressure tank/switch/gauge so not sure if that is causing any issues.
2. Also, with the CSV bolt all the way completely removed, I have only seen as low as 40psi, not the 15-25 as indicated in the installation manual.
Please advise.
Drew
Please advise.
Drew
