I recently had to replace the old valve in my toilet tank with a new one because the old value was not filling the bowl up with water when flushed. When went to the store to buy a new one I chose a FluidMaster as opposed to a Korky value as the FluidMaster was a bit cheaper and I had prior experience with installing FluidMaster valves and never had problems with any of them.
The install of the new valve was flawless and after 30 days I thought I was all set until about 2 weeks ago when the FluidMaster stopped filling the bowl. Looking in the tank I discovered that the tank was low on water and when I barely touched the float valve switch the tank started filling. This behavior continued for a couple of days until I moved the float valve switch up and down a bunch of time and then things started working normally again until yesterday when once again the FluidMaster again stopped filling the bowl and tank.
Since this happened a second time I called FluidMaster and the tech told me that this was a "common problem" and that sediment had clogged up the hole in some rubber part in the valve. The tech told me that I needed to turn the water off, pop the blue cap off the valve, remove the rubber part and clean it, place a glass over the value, turn the water on and let it run for 10 seconds or so, turn the water off and reassemble the unit and turn the water back on. Well, once again instead of doing as the tech instructed I again moved the float valve switch up and down a bunch of times and again things started working normally.
So my question is to all of you more knowledgeable people (grin) is whether this behavior for FluidMaster units to clog up like this is really a common problem? If so is this a one time clean up of the rubber part or will this be an ongoing issue? Since I was now able to get the FluidMaster to work simply by moving the valve switch up and down a bunch of times without cleaning the rubber part, do you think that this is the problem the tech was referring to or something else? Did I make a mistake buying the less expensive FluidMaster over the Korky and would the Korky work better than the FluidMaster? Bottom line is that I'm not a plumber, I'm a consumer who just wants a working toilet and not have to deal with issues. If a Korky would work better than the FluidMaster I'll go buy one. Please share your thoughts. Thanks.
