Pmurphy
Hello. So I’m in a bit of a bind with my well. Thursday night my water pressure slowed to a dribble. I went to my well and it was running nonstop and the pressure gauge was reading 30 psi. I turned the pump off via the breaker and the pressure gauge went to zero. I then tried to prime the pump was unsuccessful. I ended up hooking a garden hose from my neighbor to my line so I would have water. The next morning I began troubleshooting. I finally got the pump to prime after pouring water for close to an hour. But it was the same results as the previous night. Gauge read 30 psi while pump was running buy immediately went to zero when it was shut off. Also the tank was reading zero psi. I repressurised the tank but struggled with getting it right as I didn’t know what to set it at since my gauge wasn’t showing a reading and my pressure switch wasn’t at factory setting. Also I changed the pressure switch as the points were burnt and replaced it with another I had. I managed to waterlog my tank a couple of times and eventually changed out the whole pump with an extra I had. Eventually things seemed to go back to normal and I thought I had fixed it. Well I wake up this morning to the same thing. Again it takes me FOREVER to prime the pump. Like an hour. So I’m thinking maybe my foot valve is bad and that is what is causing my problem. I’m pretty sure I have an air leak in my tank. It is very slow though but that wouldn’t be causing my gauge to fall to zero after the pump shuts off? Sorry for the lengthy post but I wanted to be very detailed. Thanks in advance for the help.
