The size of the opening is more than adequate to provide as much as a code compliant shower head can output, letting it function as designed. If you modify things, it may not be, so more volume can help. Again, seems you are confusing volume with pressure. A bigger outlet in the valve will allow more volume, but won't affect pressure on the line. The only time volume is an issue is if the outlet is larger than the supply. When that happens, you won't get the velocity increase as it goes through the shower head's restriction jets. You can see this with say a garden sprayer. As you open the valve, the spray starts to go further until at some point, it remains the same, regardless of how much more you open the valve...you've reached the maximum flow allowed by the openings of the outlet.
The water pipe in the street has the same pressure as the line going to your house...it's just that it is much larger in diameter and can flow more volume without friction overcoming its natural flow. That doesn't mean your house has less pressure than at the street in the main line.
You want your supply to be at least the volume as the outlet, preferably slightly more. With a stock shower head, the normal outlet of the valve is going to provide that. Change something, then it becomes questionable and more volume may be useful.
Modifying your shower head to allow higher flow also means depleting your WH volume quicker, if that's a factor to you.
