scoobs
Howdy all,
I'm wondering if there's a standard depth to placing a tub filler relative to the tub. Should the spout be directly over the drain in the tub? I'm doing a wall-mounted tub filler over a claw foot tub. The depth of the tub filler from the wall will be between 7" and 8 1/4" (from wall to end of spout). The claw foot tub is 70" long and from the edge of the tub to the drain is 11" +/- 1".
I'm thinking of hitting it just behind the drain to clear the overfill on the tub (3 1/8" in from the edge), but wanted to get opinions on it. I'm trying to center the tub between two walls so this dimension determines where I build my new wall.
Attached are the drawings of both fixtures and floor plan where the tub is.
Thanks! Jon
Thanks! Jon
