Poly drop pipe clamps
Thatdarncat
South Carolina
Hi Folks,
I finally got a pump on the way but I have one more question.
First the details: I'm using one inch poly drop pipe rated for 200 psi.
Would you folks use pinch clamps or hose clamps?
I plan on using several at each joint....I'm kinda leaning towards pinch clamps because I ve had mixed results in the past with hose clamps. If you do reccomend pinch clamp, is there a particular type you would use?
If I don't end up going with hose clamps I will probably use ideal brand
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
No matter what brand of clamps you use, be sure and wrap over them tightly with electric tape. Sometimes the worm is made of harder stuff than the clamp and will rust out if not covered and sealed fairly well with electric tape.
