Thatdarncat
Hi Folks,
I finally got a pump on the way but I have one more question.
First the details: I'm using one inch poly drop pipe rated for 200 psi.
Would you folks use pinch clamps or hose clamps?
I plan on using several at each joint....I'm kinda leaning towards pinch clamps because I ve had mixed results in the past with hose clamps. If you do reccomend pinch clamp, is there a particular type you would use?
If I don't end up going with hose clamps I will probably use ideal brand
