jtech1
I have a Polaris PBG102-50T100-2N that I put in service about 12 years ago. It has been having an issue for quite a while... from inside it sounds like just a whoosh at ignition (not even obvious that it is an issue from inside sound). But, from outside (which I did not know until I happened to be under the PVC vents last week) it sounds like a backfire or gunshot. From what I can tell, that indicates a delayed ignition. I am going to have an HVAC tech come out with a manometer and check the gas pressure and gas valve. Is there anything else that could cause this? Could an issue with the in or out vent, or burner needing cleaning cause this?
Is it possible that it could be fixed with just a service call and adjustment or am I likely looking at a new gas valve or burner?
Any safety issue?
At what point is it better for me to just replace the unit? Since it is already out of warranty... and even a stainless steel tank will not last forever.
And if I want to replace it, what are my best options today? This is a 100,000 BTU, 50 gal, direct vent, condensing unit. We have not had ANY problem with the water it provides, except that we could never fill our large master bath tub before the hot runs out. So, I either need a larger unit (BTUs and/or gallons)... OR, a smaller unit and put some point of use electric heater at the master bath tub (I do have #6 wire I ran there for a future steam unit for shower that I never installed). My only requirement is that it is direct vent/sealed combustion if gas. But I am open to other non-gas options if they would meet our needs. 3-1/2 bath house. Aside from master bath tub, no other big hot water uses. I do also have a passive siphon recirc line on the hot side also... to keep hot water at the farthest fixtures at all times.
I would appreciate any advice!
Any safety issue?
