Alternety
Like an engineer
I realize this is not a query of something broken. But with my headache and tired eyes from Googling, I am hoping this is an OK question.
I have a walk in shower for my wife's bath. It was never finished. The walls are covered with cement board There is a rough-in for an obsolete Hansgrohe single fixed shower. My design was always for a wheelchair accessible shower.
I have not found a set of components to work with the rough-in. The installed device is long discontinued and does not support a handheld. I will probably need to cut a big hole in the cement board and put in something completely different. There is a single pipe from the rough-in to the fixed shower coming out of the wall.
My wife has been diagnosed with Parkinson's and I am trying to build a walk/roll in shower and bathroom for her. With all the ADA bells and whistles. She already has a problem just walking. A wheelchair is inevitable.
I have spent a seriously large amount of time trying to figure out what I need.
My parameters.
Fixed shower head using 1.5 GPM technology. State of the art seems to be shower heads with a significant number of spray patterns with flow adjustments and air infusion to improve impact results with lower flow rates. Pretty much what I also want in both the hand held and fixed head. Water pressure is not a limiting issue. I run 40-60 for house pressure. There is significant buffering. Thermostatic and anti-scald are a requirement. Ideally a low height control for temperature and flow.
Spending days on the internet, I have found a range from fraud, to hideously expensive, to completely inconsistent reviews for the same equipment..
I need easily accessible controls for the handheld and fixed head. This means not requiring someone to stand to use the shower.
I would really appreciate getting the herd knowledge of this issue. Most likely there are various personal favorites. That is just fine if you could note what the particular features cause you to recommend a certain product/model.
My parameters.
