Runekey_69
can anyone describe the process of adding a pitiless adapter? i assume that the piping is tied and tightened off at the inside of the final section of well casing before it is lowered into the well, and this is done so that the other outside half can be added.
does anyone have tips on making this run smoothly? i feel like i will have problems with my pump depth during this step.
I would drill the well untill i hit water table, then drill a little deeper *i would drill deep enough so my final segment of pvc casing would be 4.5 feet below grade
next I would remove the 6inch drill bit
next I would continue adding 6inch pvc casing consecutively
on the final pvc case I would pre configure it before dropping it down and where i can access it 4.5 feet down outside the casing
