photocell light
Hidden 1
TN
i have a outside light that uses a large sodium bulb with a photocell.comes on at dark off at dusk.i changed the photocell a year ago w no problems ,but lately it has been off and breaker tripped as i come home .reset it then 2 days later breaker tripped- back on all night after reset.-is this a sign the photocell is going out?in the last 5 years i have never had a problem ,always working.
any suggestions?
Jimbo
San Diego, CA
HPS bulbs have a feature called end-of-life cycling. They will be on for a while, go off for a while, back on , etc. This should not trip a breaker. I would just take out the photocell to rule that out, and if the problem persists, replace the bulb, and finally the ballast.
Usually parts for a light such as this cost more than a completely new fixture. There are several things which could cause the breaker to trip. A loose connection at the breaker, a bad ballast, etc., but the photo cell should NOT be able to trip it, unless its circuitry is shorting out periodically.
Hidden 1
TN
I had a feeling it could be ballast since its got a louder of a buzz after the reset of fuse .
I may just replace light .I dont think the sodium bulb can factor in on the louder buzzing than usual.
