wwhitney
A 1/4" PEX water connector such as the following comes with captive 1/4" compression nuts and a tapered fattening at each end, as you can see in the picture.
The instructions tell you to hand tighten and then tighten 2-1/2 times with a wrench. The result is that when you disassemble the connection (or at least my one sample connection), the PEX end has been deformed into more of a cylinder with a flange above it. I.e. the very end of the taper got squeezed into a cylinder, but the fattest part of the former taper is still about the same diameter.
So is that end reusable to reconnect? If so, only for the same connector (that it was originally attached to), or should one expect it to still work for an arbitrary 1/4" compression connector?
Cheers, Wayne
Cheers, Wayne
