Nicholas Meyers
Hello, I was hoping to get the input of some experienced installers on a PEX-A fitting leak.
I accidentally switched my hot and cold supply lines coming up from the basement and had to put the tee for the toilet in the cold water line after I had already run it through the floor joists.
I just have a manual tool and it was awkward using it between the joists because the arms are too long-I had to bend the tubing more than when I first installed all the other fittings (none of which leak) and was able to put slack in where I needed it to have room for the tool.
The tee to the toilet (in its proper location on the cold line) had a few drops per minute coming out when I tested it. I'm guessing the awkward angle maybe caused me to expand the tubing and ring more than usual???
I hit the tee with a heat gun for maybe 30-45 seconds, and that stopped the leak.
A day later and it is still holding under constant pressure.
I am just wondering if this is a common situation, where you get a drip that goes away.
I am tempted to just leave it be, if it continues to not leak for the next couple of days.
But peace of mind is important and I dread having to go into the ceiling months from now.
I would put in another tee without hesitating if I had the $400 manual tool which would fit in between the joists no problem. With my manual tool I fear repeating the same situation.
I can also re-run the entire cold line if that's what is necessary.
I realize it's a judgement call, but just curious what you experts think.
Thanks,
Nick
Thanks,
Nick
