MichaelSK
Here's an update. (Remember we live in north central Florida - LIGHTNING STORMS.)
Reach4 (used conversation modality from this forum) was a helpful in discussing the findings of a megohm meter.
I discovered, after digging a hole about 1' deep, that the house ground was not intact (the electrician 30 years ago used a galvanized ground rod, zinc -or pot metal cheap wire connector, #6 solid copper on a 200 amp service) very little of the zinc connector was left to be seen.
The wire in the mechanical room connecting the pressure switch, on/off switch, pump control box, and well UF-B cable was low voltage primary wire.
I temporarily fixed the grounding system. (Will start a conversation on the electrical forum about grounding and routing wire, etc.)
Took out all the piping and redid all the piping, installed a CSV valve.
Took out all the wiring/junction boxes, pressure switch, etc. and replaced all the wiring (greatly simplified it - far fewer pigtails), put the wiring in new nonmetalic watertight conduit.
Well, it didn't work because the Merrill pressure switch I got from TX was defective. So I went to the local big box store, purchased a 30/50 Square D. Installed the new pressure switch, adjusted the pressure on the the CSV - and I couldn't be more happy. I HAVE WATER, and the water to air heat pump works - a cool dehumidified house. Hooyah!
I am going to post some pressure readings, that CSV valve is very interesting. Wish I could post some photos, but haven't a clue how to get phone photos onto the computer.
Thanks for all the feedback from everyone.
