3 hp 3 wire 240 volt Control Box
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by bobfromtexas, Oct 8, 2019.
  1. bobfromtexas
    bobfromtexas New Member
    May 15, 2013
    texas
    I have a 3 hp 3 wire Gould pump that does nothing but fill the pond that has another pump that irrigates the lawn. It runs most of the time to keep up.The other day it stopped working. The breaker was not tripped. The start capacitor was leaking so I replaced it. Still nothing. I disconnected the pump wire at the well. No voltage. The points are closed on the pressure gauge. It reads 240 at the line side of the controller but nothing on the load side. Could a shorted pump have fried the controller ? I have a new controller ordered but don't want to damage it if the pump is the problem. Thanks for any advice.
  2. VAWellDriller
    VAWellDriller Active Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    Try resetting red overload buttons on bottom of control box.
  4. bobfromtexas
    May 15, 2013
    texas
    VaWellDriller...sorry I forgot to mention that. They were ok.
  5. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You probably have a "Deluxe" control box with the power relay. If the relay doesn't suck in you don't get any power out of the box.
  6. bobfromtexas
    May 15, 2013
    texas
    Thanks for the reply valveman. Yes it is the deluxe cb30412mc box. I took the power relay out and wire it like a standard box. It works fine controlled by the circuit breaker. I have a new deluxe box on the way.
    valveman likes this.
Similar Threads: wire volt
Pumps and Tanks Well Forum & Blog. Water is life. Is my Well pressure switch wired right? Feb 10, 2020
Pumps and Tanks Well Forum & Blog. Water is life. Well pump with Red, Black & Green wires - connection and cycling question Dec 12, 2019
Pumps and Tanks Well Forum & Blog. Water is life. OVER-SIZED PUMP/UNDER-SIZED WIRE? Aug 22, 2019
Pumps and Tanks Well Forum & Blog. Water is life. 25 amp dual pole breaker on 12/2 wire Jul 30, 2019
Pumps and Tanks Well Forum & Blog. Water is life. How to wire float switch? Jul 2, 2019
