RAK
I'm replacing a 35 yr old 3/4hp Franklin/Aermotor Pump and considering upgrading to a 1hp. The 3/4 pump worked fine (I don't know what the performance curve was) to supply two residences and some irrigation. But we live in a wildfire area and may want a fire protection ("Halo") system that would require increased volume from current use. So the question regards power consumption and the judgment of whether the larger pump is worth the increased operating cost for the sole purpose of an unlikely but still possible future wildfire? If two pumps of similar efficiency, operating well within their best efficiency range, are operating at the same volume and pressure, does the 1hp use "significantly" more electricity than the 3/4? We pump from an 8" well, 185 ft deep, pump set at 100', water level at 30' with about a 5' drawdown after 3hrs at 27gpm. We pump at 40-60psi and have an 85 gal hydro tank. Also, for extended (6hr+ @ 12gpm) irrigation operations, would a CSV be beneficial? Thanks.
