Seaneys
Hello,
The plumbing inspector is asking that I use a no-hub ADAPTER with the no-hug fitting in my dwv system. The connection is from 3" pvc to 3" pvc (not buried).
Are these a common fitting? They are not referred to on the Fernco site and the local plumbing supply store was not certain how they should be used.
Is there a special no-hub fitting / gasket for use with the adapters? The fernco no hub fittings look like they might be about 1/2 short.
Thanks a ton!
Thanks,
Steve
Thanks a ton!
Thanks,
Steve
