New well pump
PanteraMatt
New Jersey
My water pressure has slowly been getting worse over the last year and its at every faucet. I have a shallow well with a 1/2hp flotec jet pump thats about 4-5 years old. Its noticably louder and when the water is in use it drops to 30psi and will stay there instead of climbing back up til you turn the water off. Should I take the pump apart and see if its blocked up with sediment or just replace it? What other causes could it be? Foot valve? One way valve? If I replace it will an iron pump be louder? I was looking at this one thats very inexpensive and more powerful: https://www.homedepot.com/p/Acquaer-...910770#overlay
WorthFlorida
Solutions
Orlando, Florida
If you can, remove the jet and clean it. If it's attached to the pump motor you may need new rings. If it is down in the we'll (two pipes), you'll need to pull it out. As far as the noise, being restricted of water you maybe hearing captivation, a swirling bubbly noise. Motor bearing noise could also be a cause that may sound more metallic. A bad foot valve you'll usually lose prime.
1. How high does the pressure go before the pump shuts off?
2. Have you noticed air in your water lately?
Akrobinson18
Lempster NH
We are having this issue where our new 3/4 hp jet pump for our shallow well won't raise above 30 psi. We do have air in our water. We just replaced the old pump because it died, but was working with no air in the water before, and had no psi issues. It just randomly died. New pump is same specs. Do you think adjusting to 20/40 from 30/50 would help?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Sounds like you have a leak in the suction line. It doesn't take much of a leak to cause that problem. Water will not come out of the leak, air just goes in. Use foamy shaving cream to find the leak as you can see a hole sucked into the shaving cream.
Akrobinson18
Lempster NH
I'll try that, thank you! Second question, I'm noticing air bubbles in the water filter occasionally. So there's definitely air coming in somewhere; that still sounds like a suction line leak and not something with the tank?
