Kallisti5
I purchased a properly with a newly drilled well (400ft, pump at 340ft, 8" bore) . Everything was fine at first, but after a week or so we began to get *STRONG* sulfur odors from the well water. Running the water for 20 minutes or so seems to reduce the odor.
I did a well test and came up with a positive for coliform bacteria. After some research I read that wells normally need shock chlorinated after drilling or maintenance to sanitize them and kill off harmless sulfur producing bacteria.
I've gotten little to no help from the drilling company, and the property is kind of out in the middle of nowhere. The way the well cap is designed, it looks like it's going to be difficult to gain access to the bore. Any tips? I assume I can unbolt the sanitary cap and lift it up after undoing the pvc slip joint. I've read you can use the vent pipe, but it doesn't look possible to remove it given the configuration.
