New water and waste pipings (Help)
redknight15
philippines
Hi every one I would like to ask help on designing my newly planned house for water and sewer lay out. thanks in advance. lay out 001.jpg
Winslow
Hawaii
where is the water and sewer located in relation to the house? Can't lay it out without knowing where you're going to/ coming from.
redknight15
philippines
Thank you for your reply sir. I have included the sewer line and the water meter on the left side. I hope you can help me with this.. thank you in advances 001.jpg
That is not how it works. You give the plumber the drawing and he installs it the way HE wants to, NOT how you THINK it should be. You are asking us to tell you in a single reply information that takes us HOURS to determine. I suppose those dimensions are in centimeters, but even then YOUR code requirements could be VASTLY different than ours.
Jimbo
San Diego, CA
I suppose those dimensions are in centimeters, .
If it's centimeters, the house is 328 feet wide! Probably mm.
We know freezing is not an issue. But overhead pipes in a hot attic might be. Is he house to be on a slab, a basement ( unlikely) or a raised foundation.
redknight15
philippines
I am sorry guys, I just want to ask opinion about this, I really dont have an Idea on how to install such system.
The dimensions are in mm, I only need a simple layout so I can pursue this plan. The house is sitting directly on soil.
I am sorry I am just asking for help because you are the experts here. Iam really sorry if I am a burden to you all..
Bluebinky
Des Moines, WA
redknight15,
This forum is quite U.S.-centric. It's likely no one here is familiar with the building standards in the Philippines. Metric, what's that?...
Even within the U.S. things vary somewhat by location.
Jimbo
San Diego, CA
redknight15,
WELL...it has been a few years. But I have spent some time in the Barrios...Olongapo, Baretto, etc. Let's say that at the time, if you found indoor plumbing, that was a luxury! The fact he is building with a supplied sewer main and water supply....wow!
OVerlaying the bathrooms with the floor tile grid obscures the actual lavatory locations, but if they are where I think they are, I do not like EITHER ONE.
