BDP
Ok, I'm back. Bad news, we have a leak.
It's RIGHT at the base where the reducer meets the pipe coming up out of the floor. Worst possible spot as I can't see a way of getting this out without cutting right at the base pipe which is going to not only make me have to start totally over (and buy all new pieces), but also possibly not even leave enough pipe exposed coming up out of the floor to put a new reducer cap on there.
Is there ANYTHING I can do under the lip of the reducer cap, where the arrow is, to stop this leak? A bead of silicone sealant perhaps??? I hope there might be something I can do...Even though I realize it's not the ideal solution, starting over just makes me kinda ill. What a bummer.
See the photo below. If there's something I can do, please let me know. If not, can you let me know where the smartest place to cut will be to allow me to get the sink back out (above inside the cabinet or right below the cap there?). What worries me about cutting below the cap is that it doesn't leave a lot of exposed pipe coming up out of the floor anymore.
I'd already tried putting more cement around the seam but with no luck, leak was still there -- Also did some Google research this morning and read a post from someone saying that extra PVC glue was just a temporary fix, maybe for a few months, and that I'd see the leak come back again. Is that true?
Two other fixes I saw mentioned, both of which were only temporary -- One guy recommended an industrial glue called GOOP - He said to slather it around the joint and that it would last a few months. Another guy suggested epoxy cement, but also said that due to its bonding properties it would eventually expand and allow water through. They all mentioned that the PVC cement was a bonding agent but it wouldn't serve as a leak stopper.
Help???
Help???
