Jason B
Hi, this one has me a little stumped - any help is appreciated.
I recently replaced a bathtub and toilet as part of a full room overhaul. I replaced the toilet first and noticed a dripping sound coming from the pipes underneath. This did not happen with the previous toilet, but I chalked it up to differences in toilet design, etc... I don't know if this will be relevant but thought I'd mention it.
When I connected the drain and tested it, the toilet immediately began gurgling and is now very slow to drain when flushed - it wells up and drains out over the course of an hour or more. The tub drain is also very slow, but not clogged, at least completely so. A slow drip (similar to the toilet's drip) can be heard in the main stack for a long time after the tub has been turned on for a short amount of time.
I'm dealing with a drum trap for the tub that is partially embedded in the wall, so I don't believe replacing it is an option. Just after the drum is a tee going up into a vent that is definitely the tub vent, and may also be a vent for the toilet (I can't tell, as the pipe going down off the tee goes into a wall and into the finished basement.)
I've included a diagram to hopefully show the setup a little better. The only thing I can think that might be causing the slow up is the height of the tub drain. It is within an inch of the previous setup, but that bump up puts it higher than the top of the drum. I can't find much on drum traps, as it seems they've been done away with. Is that something I could look into?
Thanks for any help you can offer!
Jason
Jason
