I recently had a bladder go bad in my tank which was causing my pressure switch to rapidly short cycle so I had the tank professionally replaced and I thought everything was fixed. I went and checked the tank because I heard the switch kicking on when no water was being used. Turns out the 40/60 kicks on at 40PSI and raises it quickly to 60PSI and then it bleeds and loses pressure down to 40PSI with 3-5 minutes and the cycle repeats.
I changed the pressure switch and gauge myself, noticed they were gunked up with iron sludge and while doing so I opened the faucet and notice no water came out of the tank. I believe the tank is not getting any water, as I could move the tank very easily. I checked the tank's air and it was around 40PSI so I dropped it to 38PSI and the tank still doesnt fill. I am at a loss here. I am having trouble getting ahold of the guy who did the work and I would rather not be told by someone else I need a whole new submersible pump etc. if not needed.
I have a high water table and use a softner.
I would very much appreciate your help. I have found no related cases to this to try and help me diagnose why no water is going in the tank while it constantly cycles between 40-60PSI every 5 minutes. Thanks.
