johnseeley
I need some basic advice on replacing my water heater shutoff. Picture attached. Actually I'm going to replace my main shutoff as well, but that's easy since I have enough flex in the pipe.
But with the water heater shutoff, I have no play to pull the pipe apart 3/4" to fit the new valve unless you think I'd have enough flex. I plan on hack sawing the old valve collar and then removing the 2 sections of valve to keep enough pipe to add the new valve. Or do you think replacing the whole section from elbow to elbow is better and add a compression union above your below the valve? Thanks.
