Moving Toilet, 2 --45's OK?
newmex999
nm
I need to move my toilet a few inches to the side.
How do you guys feel about using 2-45's to do this?
My toilet is on a slab and I have already broken up some of the concrete and removed about a foot of dirt.
I was also toying with the idea of using one of the better offset flanges, however that will only allow me to move it about 2" and I need more llike 4"-5"
You can have up to 135 degrees of change.
To move it just a bit, I will often use 90 into a street 45.
That moves it about 4" with only 45 degrees of change.
newmex999
nm
More Questions
Hi Terry:
So am I ok using the 2-45's?
And how do you use the 90 along with the 45, I am trying to picture this and the angle seems incorrect?
The flange I bought has a stainless ring and is a 45 and then I purchased another 45
Frank
A closet flange with a built in 45?
That would work too.
You can have a 90 and a 45 on the horizontal.
They don't count the vertical to horizontal bends.
newmex999
nm
I am not doing anything with the horizontal, I am just changing the vertical with the 2- 45's at the top of the vertical run.
I'll move forward and install the 2-45's and bring back the offset flange to the big box store.
Thanks
