Move toilet flange
Joey43
GA
I have access to all the drain components and the 3" basement slab drain. The drain pipe needs to be extended about 1" to better locate the flange. two questions:
How can I extend the horizontal 3" PVC drain pipe approximately 1"?
Is it worth the effort to get the toilet closer than 1.5" to the wall?
I suggest that you post a photo of what you can access.
You have access to the drain pipe, and it is in a slab????
Most toilets will have between 1" and 1/2" behind the tank on a standard 12" rough to finished wall.
I would not bother with breaking concrete to change that if it were my home.
Joey43
GA
There is a hole with access to all pipes including the 3" drain pipe so no need to break out concrete. If I can attach a coupler or something to extend the 3" drain pipe about 1" to 1.5" I can get a better fit. I bought a 3" coupler, but am not sure that will help me extend the length of the pipe.
Any suggestions would be appreciated.
Thanks
Tuttles Revenge
If you are extending the pipe further from the wall to gain space. I would start by finding the end of the horizontal hub of the elbow that you're removing. The coupling you install will have a hub of 1.5" on each end.. so 3" in total. So say you place that coupling on the horizontal pipe at the end of the elbow hub, you would cut where the center of that coupling is. Then when you replace the elbow, your pipe you glue in would be 1" longer (or whatever length you want to add) than the stub out of the cut out pipe.
