Mounting copper manifolds?
JCH
Victoria, British Columbia, Canada
I am replacing the trunk-and-branch copper supply plumbing in my house with a PEX home run system.
Turns out that it's not very common here and even finding manifolds is challenging at the local plumbing supply shop.
I eventually found these:
http://www.bow-group.com/Pages/popupProduit.aspx?cat=57&pro=25043&LANG=EN&path=540922&ip=US
but the plumbing store had no idea how people actually mount them. All they had were 1" J-clips...
I'll be running 3 manifolds (hot, warm, cold) in a compact space and have only been able to find dual-manifold brackets online (none that will stagger three of them):
http://www.sears.com/viega-pex-viega-17145-proradiant-1-inch-copper/p-SPM12011884719
I saw another thread on this forum that suggested building wooden brackets...
Any other ideas? Thanks!
.../j
Some people use manifolds that have valves to allow shutting down lines. Some come with integral brackets.
Not all PEX is the same, so you will want to check if yours is compatible with your manifold.
JCH
The copper manifolds I bought are the Bow manifolds above. 3/4" PEX crimp in, and 1/2" PEX crimp out on each branch. I'm going to install PEX ball valves on just the lines running to the showers.
At two different plumbing stores (yes, the ones that real plumbers go to), I got the same answer: "Gee, I've never looked up to see how people mount them". At one place, the plumber behind me in line asked me what I was going to use them for!
I asked for Bell Clamps (nope). Also asked for Van Clamps (nope). They just don't seem to do manifolds in this town.
Was hoping someone could steer me towards something that'd be available online in Canada.
Sheldon
Edmonton, Alberta
We use a system called StarQuick. You secure them with a drywall or deck screw. You can also get spacers for them if you want to stagger your manifolds. Im from Alberta so they are here in Canada. www.starquick.info. Hope this helps you out.
JCH
CountryBumkin
Active Member
Orlando, FL
I did not use anything under the straps.
There is no noise transmission issue since the piping to/from the manifold is PEX - there is enough flex in the PEX to allow for normal pipe expansion/movement during use.
JCH
Okay, good. I was thinking more along the lines of water turbulence noise (the sound of running pipes) being conducted into the structure.
No, you arrange them side by side, on the wall, and mount the two outside ones to the middle one using your two manifold brackets.
JCH
No, you arrange them side by side and mount the two outside ones to the middle one using your two manifold brackets.
So: 1) The middle manifold is attached by a bracket on each end (i.e. by 2 brackets), and 2) the two outside manifolds are each attached by the remaining free clamp in each bracket (i.e. each outside manifold held by 1 bracket)?
