Loud thud/slapping noise after well pressure tank cut off at 60 psi
willinnj
Turn off the breaker, cut above n below the T with a tubing cutter, back the T out of the control center, unwire the control center, back the control center off the adapter, gut the control center and reassemble with sweat unions or Sharkbites if you can't sweat a joint.
All done in 45 minutes, $325-350 tops including tax.
Thanks! I am afraid it may be beyond my skillset and I don't want the wife to nag at me for leaving us without water so I am going to ask a plumber to see if he can help
willinnj
See if the plumbing class will come in and do it
:) I wonder if they will do it if this is actually a requirement in central NJ. The well companies that I called told me it is required.
Or do you mean for them to switch out the checkvalve with a new one?
Thanks.
Craigpump
The plumbing class would have to follow code.
You might get the class to come in and do the job for you. It'll definitely take longer, but so what?
willinnj
Great! Thanks for the suggestion. Appreciate it.
I will call around and see.
