I installed a new ISE Badger 9 disposal a week and a half ago. A few days later it was dripping, but not from any connections. It was leaking through the motor and out a body assembly screw- a defective unit. ISE hooked me up with a local appliance repair company for warranty service. I had to wait a full week for the repair because they said they had to use a Badger 9 direct from ISE only, because I guess the factory tests all warranty replacement units in order to rule out factory defects in any future warranty claims.
The repair guy seemed to know what he was doing- he sure told me he did- told me he had 16 years experience installing these things.. well he forgot to punch out the DW plug. Idiot. He tested the disposal, but of course not with the DW going.
So tonight, one day later, I run the DW and it floods my counter and onto my floor by the force of the drain water through the air gap (mounted in the sink). Luckliy I was awake and got the DW turned off (I thought). I took of the DW line from the dispoal and found, as I expected, the plug still there.
But in doing so I bumped the DW closed, which started it again, and drain water started pouring out of the unattached air vent line.. in my haste to get the end of the air vent line over my bucket, I then knocked the P trap off the other sink's tailpiece and I actually broke the black plastic tailpiece that is attached to the disposal's slide-in gasket attachment, right at the gasket.
It is to late to get hold of the appliance repair people tonight. My opinion is their faulty install caused all of this.. what do you think?? Finally, there is my question..
I think my panic reaction was understandable, as the kitchen was flooding.. I think they are liable for fixing my undersink plumbing. And, if the disposal gasket got damaged it maybe would not be covered by any warranty, but again, I think they are ultimately responsible, and if the disposal needs replacing, they should eat it. And, now our kitchen sink AND new dishwasher are OUT OF COMMISSION until this is resolved.. which would also be the case eve if I had not damged the plumbing, because you cannot knock out the plug now while the disposal is installed (according to the instrucutions- again a warranty issue) . The sad thing is a plumber would charge at least $500 to fix all of this BS...
