Hello All. Came across this website doing my endless research to try to solve this issue. Woke up this AM and the waste arm had a hole causing a leak. I replaced the arm (as well as an additional pipe linking it to the trap) without issue.
However, the slip nut connecting the top of the tailpipe to the sink strainer basically broke. I attempted to connect the tailpipe to the sink strainer with a different slip nut but I'm getting a leak from the connection if I run the water more than halfway (or dump something in the sink). I inspected the flanged washer at the connection and while old, doesn't appear cracked. I am having some trouble getting a good, tight connection with the slip nut. I'm worried it is/was crossthreaded. I'm attaching a picture.
When I've removed the tailpipe and just screwed on the slip nut the connection seems better but when I add the washer I run into the same issue of it being tight but obviously not on properly (If I overtighten it blasts right through and loosens again which may be indicative of the issue). Any ideas would be great. I've had three thoughts myself: 1) replace the washer (possibly with a rubber one...current one is plastic)? 2) replace the strainer as the threads on it might be shot? 3) Utilize tape/dope on the connection but I had read on here that slip nuts should be a perfect seal and don't require that. Thanks in advance for any help.
