Hi, I currently have a washer setup that drains into a 2in standpipe. I would like to add a laundry sink and have the washer hose drain into that so I can add a lint sock. I'm having a little trouble figuring out all of the different connection sizes. For the hot and cold supply lines, is there no way to run a splitter off of the valve that supplies the washer? I know the washer valve size is 3/4 in and faucet supply lines are 3/8 to 1/2inch. Would I need to leave that alone and just install a T fitting into the hot and cold lines ? I did see they sell a dishwasher line that is 3/8 on one end and can go to 3/4 on the other side.
Second part of my dilemma is the drainage. So the current standpipe is copper. Do I cut it, add a rubber coupling and attach PVC ? If so what type of reducers would I need since drain p trap lines are 1 1/2 or 1 1/4. Hope that makes sense. I attached some pictures to help.
