Kohler transfer valve rough in depth
Jimmy k
Rhode island
Hi ..I am installing a 2 or 3 way kohler transfer valve and trying to rough it in for correct depth. My finished wall will be 1 inch thick and the framing is 2x4. If I follow the directions I have to use less than a 3/4 inch cleat between the studs for correct depth...this is much less than the 1 and 1/2 thick cleat used per directions for the rite temp mixing valve mounted under the transfer valve...any help would be appreciated thanks..jim
James Henry
Billings, Montana.
You can simply mock up your wall by placing a couple 2 x 4 blocks on the floor and lay something on the blocks the the thickness of the proposed finished wall and then you can determine the correct depth for the valve. I have also made the holes in the 2x 4s next to the valve large where the hot and cold lines attach so I can shim the valve out towards the finish wall if need be.
