Kohler Coralais single handle shower cold and valve loose
Adawgie88
Detroit, MI
Kohler CORALAIS K-P15111
K-P15111-4 With Lever Handle
K-P15111-7 With Sculptured Acrylic Handle
The shower in my master bathroom has dropped forever. I had a buddy who said he could fix it. Well, he left it a mess.
Now instead of dripping it only dispenses cold water and the valve/handle is loose.
I’m wondering if the cold water issue is simply the need for a new cartridge. I’ll try to figure out what’s needed to replace that.
Any idea why the valve would be loose? By this I mean when you go to turn the single handle lever it literally moves side to side. I have no access behind to brace with wood, and it was never loose before he “helped.” Is there a way to brace this?
There is an odd black round circular piece behind, but I think that’s for use when using in a tiled shower.
While I’m at it, any guesses on the cartridge and handle trim, since both need replaced.
Thanks in advance for the help. I’m so frustrated.
Pics:
https://photos.app.goo.gl/qW4bdctCxQa1orVy7
That black plate behind was most likely used as a backer to hold it in place. Normally a block out for the tile, but also works well was backing in a fiberglass shower.
index.php
Adawgie88
Detroit, MI
Is there a trick to getting it back in place? Would love to get this shower back up and running!!
Thanks to both posters for the help thus far.
Adawgie88
Detroit, MI
Fixed the cold water issue. Somehow the valve was turned so the max hot water limit was was on way too cold.
Now to figure out how to get the valve secured and I’ll be sitting pretty.
Most valves have a section in their installation manual called something like 'thin wall installation' method. As Terry indicated, the plaster guard is often used on the back side of the enclosure to sandwich the valve to the wall, providing stability and to prevent you from flexing the wall away from the trim. WIthout it, you'd have to juryrig something up to emulate that.
