Kitchen sink drain
Ron Franssen
Kansas
Hello, here's a quick description. Using a large (deep) farmhouse sink with single discharge. Garbage disposer is also large. Only about 4 inches between edge of disposer and the stub out on the wall. Is it acceptable to put a 45 on the stub out (not going up or down but rather parallel) to "move" the stub out for the adapter that the trap/return could feed into. I have the disposer positioned so the discharge is turned 90 degrees from the stub out.
I can provide more information if required but I know everyone's busy and short ?'s are generally appreciated.
thanks
Ron
Probably. I suggest you post a photo.
If you have a trap adapter at the wall, you could cut a 1-1/2 double-offset tube to make a piece that could help you with this. You can mix materials with slip-joint drain parts.
22 gauge is more common, but the thicker 17 gauge is available too. The OD is the same on each.
Ron Franssen
Kansas
Thanks for the information. A single street 45 with the adapter glued to that end was all I needed to successfully connect the waste discharge via the p-trap. Appreciate the responses.
