Kitchen sink drain
Discussion in 'Plumbing Code Questions' started by Ron Franssen, Apr 22, 2019.
  1. Ron Franssen
    Ron Franssen New Member
    Apr 22, 2019
    Kansas
    Hello, here's a quick description. Using a large (deep) farmhouse sink with single discharge. Garbage disposer is also large. Only about 4 inches between edge of disposer and the stub out on the wall. Is it acceptable to put a 45 on the stub out (not going up or down but rather parallel) to "move" the stub out for the adapter that the trap/return could feed into. I have the disposer positioned so the discharge is turned 90 degrees from the stub out.
    I can provide more information if required but I know everyone's busy and short ?'s are generally appreciated.
    thanks
    Ron
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Probably. I suggest you post a photo.
  4. MASTERPLUMB777
    MASTERPLUMB777 In the Trades
    Aug 6, 2007
    Retired Master Plumber
    Texas
    YES YOU MAKE THE CHANGE OF DIRECTION THEN USE THE P TRAP TURN
  5. Reach4
    Sep 25, 2013
    If you have a trap adapter at the wall, you could cut a 1-1/2 double-offset tube to make a piece that could help you with this. You can mix materials with slip-joint drain parts.
    22 gauge is more common, but the thicker 17 gauge is available too. The OD is the same on each.
  6. Ron Franssen
    Apr 22, 2019
    Kansas
    Thanks for the information. A single street 45 with the adapter glued to that end was all I needed to successfully connect the waste discharge via the p-trap. Appreciate the responses.
Similar Threads: Kitchen sink
Plumbing Code Questions Longest horizontal branch for kitchen sink Sep 21, 2018
Plumbing Code Questions Kitchen Island Sink Vent Jun 14, 2018
Plumbing Code Questions New York - Connecting Washing machine to Kitchen sink - Is Permit Needed Apr 19, 2018
Plumbing Code Questions Venting using a horizontal drain from kitchen sink OK? Dec 16, 2016
Plumbing Code Questions Kitchen sink vent and large window Jul 21, 2016
