Intermatic FM/1 timer losing time
Gpace1
Retired
Austin, TX
I am struggling with this timer losing time. The timer controls a sprinkler that is attached to my OSSF. This is an aerobic septic system that pumps out through sprinklers. I began to see the sprinklers running at odd times. The current time setting on the timer was losing time. I replaced the timer but it did not fix the problem. I suspect the timer clock motor is losing power intermittently. I am going to check all connections next. Could the breakers be bad?
Gpace1
Retired
Austin, TX
**UPDATE** This problem is solved. The new timer was missing a jumper between posts 2 & 3. Soldered one in and all is well.
quote; The new timer was missing a jumper between posts 2 & 3.
Unless YOU had it wired incorrectly, that should have had nothing to do with the timer motor. Terminals 3, 4, and 5 are "load" terminals and only switch the "power" to the device, (which could be ANY voltage, or AC, or DC), which has NOTHING to do with the clock motor
