Install washer&dryer power supply outlets on one stud ?
charles w
MANITOBA CA
AF1QipMilyFHXcPysXUSR8knoHHaiX61WMcNz-p17yJz
Hello
I have a question like what I draw in the paper.
https://photos.google.com/photo/AF1QipMilyFHXcPysXUSR8knoHHaiX61WMcNz-p17yJz
The reason is I don't want to cut the exist drywall too much,
just want to do the electrical work near the washer plumbing area.
220v outlet above the 110v washer plug , is it ok?
thank you for your help!
WEll, your link reports an error, and you can't cut and paste a picture...you need to use the button "Upload a File" and select it for uploading.
Not sure you'd find a cover plate for a box that had both the 120vac and 240 plugs in it. Don't think that that is a code issue, though, but I"m not an electrician!
charles w
MANITOBA CA
Thanks for your remainder. I upload the draw here.
Yeah, you are right. 30 amp dryer outlets are wide.
So it would take a 6 inch box to fit the washer and electric dryer outlets.
