Install washer&dryer power supply outlets on one stud ?
Discussion in 'Electrical Forum discussion & Blog' started by charles w, May 22, 2020 at 2:53 PM.
  1. charles w
    charles w New Member
    Mar 25, 2020
    MANITOBA CA
  2. jadnashua
    WEll, your link reports an error, and you can't cut and paste a picture...you need to use the button "Upload a File" and select it for uploading.
    Not sure you'd find a cover plate for a box that had both the 120vac and 240 plugs in it. Don't think that that is a code issue, though, but I"m not an electrician!
  4. charles w
    Mar 25, 2020
    MANITOBA CA
    Thanks for your remainder. I upload the draw here.
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Yes.
    Alternatively, you could put the 120 and 240 outlets into the same 4 6-inch box.
  6. charles w
    Mar 25, 2020
    MANITOBA CA
    thank you but still confusing . I believe 4-inch box is for dryer , so I use a small box for washer . could you tell me
    more?
  7. Reach4
    Sep 25, 2013
    Yeah, you are right. 30 amp dryer outlets are wide. [​IMG]
    So it would take a 6 inch box to fit the washer and electric dryer outlets.
Similar Threads: Install washer&dryer
Electrical Forum discussion & Blog Help with installing outdoor outlets on new construction Apr 10, 2020
Electrical Forum discussion & Blog Sub-panel Installation Feb 6, 2020
Electrical Forum discussion & Blog Heater Install in Finished Garage Dec 27, 2019
Electrical Forum discussion & Blog Questions on installing timer switch Dec 22, 2019
Electrical Forum discussion & Blog Installing GFCI outlets - wiring the right terminals Nov 23, 2019
