Greg0010
My house is about 2o years old and has no-name-ish contractor-grade (Rocaille) single-lever faucets in the two tubs/showers. They both leak a little (drips from spout). This house is new to me, and while I have experience working with really old tub faucets with separate knobs for hot/cold, I have zero experience with this kind of faucet.
I have no idea what I'll find in there when I pull it apart, if I'll find some innards and just have to replace a cartridge of some type, or if I'm going to be buying a new faucet...or more. An extended period of time when I have the water shut off to the whole house while I figure one of these out isn't going to work.
So, I'm thinking I'll install ball valve shut-offs in the crawl space for the faucets' supply lines. Then, I can work on one and not be trying to rush through anything.
My questions are 1) is this kosher or is this an oddball thing to do (that might look bad when/if re-selling)? and 2) while the 1/2" copper below is accessible, it is a little tight. I'm thinking of using either a sharkbite ball valves or a compression ball valves. I haven't soldered since a high school shop class; it is all a little too close to the floor joists for my confidence with a blowtorch. For a longer term situation, would it be better to go with a compression fitting or a sharkbite?
