I can not get the tank to bowl gasket to fit on my Mansfield toilet
Miepie
florida
I have replaced everything inside my Mansfield 160 toilet. I bought a new gasket off Amazon for the tank to bowl, It has the same number on it as the old one. I cannot get the gasket to set on the valve. I even tried the old one. So when I put it on and tighten the screws the tank leaks ( with the old or the new). I think it just isn't going on straight. I have looked at multiple videos and it seems that this gasket should kind of just snap on. But it doesn't... what do I do. This is the first time I have done a toilet repair. After spending all this money I think maybe a new toilet would have been the way to go!
Michael Young
North Carolina
I'm assuming you're using the big black spongy gasket and not the red one.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
pictures might help. are you sure it isn't the tank to bowl washers that are leaking.
We always double nut so the thru tank washers have a nut below the tank and we're not relying on the tank to bowl nuts to seal at the tank.
John Gayewski
Iowa
Mansfield uses hard rubber type gaskets. I don't use those when they come in kits for mansfield. Grab a spongy one.
Mansfield in more ways than one, make a crappy toilet. My opinion.
Michael Young
North Carolina
Agreed. I'm not a Mansfield fan. I think he'd have the best outcome if he went out and replaced the toilet with a nice $300-$350 American Standard Cadet Pro (buy it from the supply house, not home dopey)
Breplum
at under $200 I have been exceedingly happy still, with the HDepot AStd Flowise Cadet 3 ada and special hq finish. just throw away the seat and junk closet bolts set. never clogs
Michael Young
North Carolina
I agree. A new toilet would have been the way to go. have you tried going to home depot and buying one of those spongy "universal fit" tank-to-bowl gaskets?
You mentioned that you replaced EVERYTHING. If you replaced everything - and now, not even the old gasket will fit, it sounds like your new parts aren't the same size as the old parts. I suspect a universal tank-to-bowl gasket will fit the new parts.
FrustratedDIYer
USA
Look at the plastic nut for the flush valve and see if it has little "wings" so it's sort of octagonal to make it easier to use a wrench.
If so, cut them flush. I am not a plumber and when I tried to put on a new gasket it leaked all over, because it kept falling off the nut. Then I saw the original plumber had cut off those little wings on the old flush valve big plastic nut. So I used the old nut and the gasket then stayed on tightly. So check that if you're still having problems.
John Gayewski
Iowa
What is wrong with buying from big box stores? Nothe same toilet - if they sell it?
Thank you.
Sometimes the pool of products big box does buy from is different than the pool for professional distributors. When they are sorted off of the production line they can be set if different piles based on quality or types of production.
Not true with all things, but generally a plumbing supplier is gonna have higher quality stuff. They also are easier to make returns to generally.
