Humiliation Sucks
FullySprinklered
Georgia
Roughed in a Delta shower valve with a diverter a couple of weeks ago. Cartridges did not come with the fixtures, so in consideration of the homeowners, I cut the hot supply to the valve and capped them with Sharkbites. This was to prevent cold water from feeding through the mixer and depriving the customers of a decent shower while the remodel progressed.
Came back for the set-out this week, got everything installed, and couldn't get a consistent flow from the shower or the hand-held leg from the diverter. Took everything apart, tried a new cartridge, etc.
Went down to the basement with the contractor, looking for clues, and he declared "it's capped". It didn't register in my brain since all I could see was a Sharkbite coupling up there. Everything else was sweated.
As it turned out, two Sharkbite caps, butted head to head, looks exactly like a coupling.
I replaced the caps with a coupling and everything started working.
Oh, how the mighty have fallen.
Trump the Plumber
Mar-a-Lago Club
Nobody knew plumbing could be so complicated. To be great, Delta makes a part that plugs one of the lines on the Delta rough. RP46079 test plug is what I use. I say this all the time. Believe me.
FullySprinklered
Georgia
Thanks for reminding me Mr President. I think I have one of those in the bottom of a bucket somewhere, but it wasn't where I needed it.
You "say this all the time"? I think YOU have delusions of grandeur. Anyway, how often does someone install a Delta valve and NOT install the plug that comes with it, if they are not installing the cartridge? I ONLY have to "say this" occasionally.
JRC3
S.W. Ohio
Exactly once. The first time you have to go back that evening to correct the "we don't have hot water" problem.
I will go with once too. That call late at night about no hot water in the other shower. The water mixes across the valve in the home wihout the plug.
FullySprinklered
Georgia
Got one now. Replaced a Moen with a Delta yesterday. Going to keep the plug just in case. Might hang it on the rear view mirror with my dreamcatcher. Incidentally, soldering in the Delta to the existing pipes leaves it 1.5 inches too deep in the wall. Had plenty of flex, fortunately.
