We purchased an older home and the tub is original (olive green).
The basement under is unfinished and when the tub drains, it leaks down in the unfinished basement.
Since the drain is leaking and the trip-lever is broken, I thought it would be easier to replace the drain with a pop-up and just put a round plate over the old trip-lever.
However, for the life of me, I cannot figure how out to remove the strainer/drain (I can take a picture of the drain from below if that is needed) to replace it. For the drain, there is no screw to remove and was hoping someone could provide a bit of help to this tub/drain novice.
Thank you and happy holidays.
