Jeff Knecht
It might be hard to be precise cutting with a hacksaw where you would need to grind or file off the burr afterwards. Grinding/filing should be easy.
You can make a die out of an iron fitting by grinding slots into it with a dremel tool and skinny disk. It is not anywhere as effective as a real die, but it will clean up threads and remove a small amount of brass material.
Right off, using a die is a little over my head right now. I'm better at cutting and mauling.
But, great idea. My learning curve and bag of tricks is filling up.
Can't believe how many of you guys are chiming in.
Thank you!
