How to clean a snyder tank
PhracturedBlue
Oregon
I have a 1500 gallon snyder water cistern which is fed by our deep-well pump. It was put in originally because we had a low-flow well and needed water storage. While we don't strictly need it anymore, I prefer to keep it because I can more easily power the jet-pump with alternate supplies when power goes out. The tank is about 25 years old, and because it has an 8" opening at the top, and is in a building with about 24" clearance above the lid, I've found no good way to clean it. So it has accumulated a significant (maybe 8"+) of sediment at the bottom. I'm trying to figure out how I can clean out that sediment. I've previously used a trash pump to drain the tank but with such a narrow hole, and so little clearance, I don't have any good way to manuver the inlet. how do people clean these things?
(I do run a recirculating pump now with a filter, so the sediment doesn't tend to accumulate anymore, but that doesn't help with what is already there).
Pressure washer to stir the sediment up, and pump the water out to the ground.
You can find a utility pump that will fit thru that opening. Utility pumps pump down much lower than trash pumps, but they are not going to pump mud like a trash pump can.
