Jrsavoie
We recently changed the 1" in/out water filter 11" tall model. The cartridge bowl was about 1/3 full of gray clay packed around the filter. The filter is immediately after the bladder tank.
When we drained the bladder tank. WE did not get much sediment out of it. I was surprised. The same with the water heater - but that is after the filters.
5 days ago, I replaced the entire filter housing with a 20" x 4.5" model the same diameter as the 11"
LF-PP-005-508-B 20" x 4.5" Gradient Density, 5 Micron, Melt Blown Polypropylene Filter .
There are just 2 of us and we haven't used a lot of water. The new filter had about 3/4" of clay on the bottom when I looked today.
The 5" PVC cased well was drilled 10/26/2002.
It has always had a sediment issue. Mostly fine clay sediment that would pass through 2 micron filters.
I have a Well Tamer installed when the well was installed. https://www.wcponline.com/product-trade-show-index/listing/taming-the-well
I fear my well has filled up with clay. I have previously blow wells out with air. I saw something called a brumby pump which looks like what I need.
Is there some type of air lift pump or something that will remove the sediment better than just an air line down the well?
I have not pulled the top cover and measured how deep the well is.
The 18 gpm pump set at 44' seems to be lower on volume than it used to be.
Originally the 55' deep well, pressure tank working cycle 14 gallons,had an estimated yield of 75 gpm.
The #30 stainless screen runs from 46 ft. to 55 ft.
static water level was 18.5' below ground level. pumping level is 22' pumping 70 gpm after pumping for 2 hours.
Earth materials passed through. Black dirt 2', Yellow Clay 2 to 8', gray clay 8 to 46', Sand & gravel 46 to 55'
I called a well driller to come blow the well. Not sure when he will be available. Or if it would help out, to do what I can before he gets here.
