hot water build up in water system
DT plumbing
Seattle
Hello Everybody;
This Is Derryn the plumber with a question
I have a customer that has hot water build up pressure
I have installed a new PRV, The problem still exist
Should I install an Expansion tank on the HWT
I am wondering if this will stop the problem
dtvansickle@hotmail.com
Thanks Derryn
SewerRatz
Illinois Licensed Plumber
Chicago, IL
www.a-archer.net
Hello Everybody;
Thanks Derryn
If there is a PRV on the system you must have an expansion tank.
pressure
The pressure should build up in the entire system, not just the hot water, unless there is also a check valve on the line to the water heater.
