Help with Delta 200 Wall Faucet
MrWizard
Phoenix Az
I have a Delta 200 Wall Faucet that I need to get repaired. It has been leaking it appears from the spout where it turns for a long time before it started leaking enough to see it dripping because the back mounting plate that the valve sits on has rusted enough afraid if I attempt to unscrew the top part to put the new parts and spout it will break off of the back plate. Delta has discontinued this model and cannot find a new one anyplace. So I am asking here to see if anyone has a working new or used one or the back mounting plate from a old one. Hope someone can help as I need the back plate at least ASAP.
Richard
You might need the RP25 O-rings for the spout.
Though this is a standard 8" spread wall faucet. You can still find replacement faucets that work on 8" centers off the wall.
MrWizard
Phoenix Az
Yes there are a few wall mount replacements but not a single one that has a cover like the delta 200 to hide the years of rust and water damage behind the mounting plate. Delta offers no solution to this issue nor any other maker. I don't want to replace the back splash as the staining between the 8 inch pipe supply lines are there to stay. I just need a new or used mounting plate for the delta 200 as seen in the parts view uploaded. Hoping someone had an old one that has been replaced I can buy the old back plate from. If anyone has old stock of new delta 200 faucet I will buy 2 or 3 of them.
Richard
DonL
Houston, TX
You may want to check a True-Value hardware store.
My old school store has old school parts like that. Including the O-Rings.
Good luck on your project.
